Dust Collection
dust collection
6/26/23
mark tyler
Im interested in finding out more about what everyone uses for dust collection. Any suggestions for a small workshop - 5 staff
6/26/23       #2: dust collection ...
Dustin Orth  Member
So many variables here. What are you making? How much fine dust vs chips or flakes? How much volume of dust per day? Returning the filter air back into the shop or a unit fully inside the shop? What power do you have available? Any restrictions from a landlord or fire department? Maybe a city/ county restriction?
7/4/23       #3: dust collection ...
I have a 20hp baghouse outside for most of the shop. A 7½hp Oneida cyclone inside for the cnc.
I would like to get rid of the baghouse and replace it with three smaller cyclones like on the cnc. Reason being it costs a lot to run the baghouse when one guy is at a pop-up saw and nobody else is needs dust collection.
7/11/23       #4: dust collection ...
Rob Young Member
Website: http://nutekmachinery.com/dust-collectors-modesta....
It would be helpful to know what machinery you are running in your facility to determine the size collector you need. The largest indoor dust collector you can have in your shop by regulations is 5000 cfm. Not all indoor collectors are created equal though. A few of the main attributes to consider are
1. Static pressure rating. I know of a brand that advertises 5000 cfm at 7 wg. If you go to 8 wg the unit is rated at 3500 cfm. That's a huge difference in performance.
2. Fan and motor size. The fan and motor will directly influence your collector performance.
3. Air to cloth ratio. The square footage of the filter media compared to the volume of air. Look for a higher square footage of filter media for better performance.
These are some very basic attributes to look at. I linked a blog I wrote on this topic in my post. The blog is basic and easy to understand and hopefully helps.
https://nutekmachinery.com/blog/index.php?five-key-specifications-of-an-indoor-dust-collector
    • GreCon
    • RT Machine Co.
    • Denray Machine
    • American Fabric Filter Co.
    • Sandman Products
    • Air Handling Systems
