Subject: Re: Spraying waterborne in the winter
1/27/15
Kevin Member
Other than flow out issues and dry times, are there any concerns about spraying waterborne in less than ideal temps? Can cold checking still occur? I have a booth and in the winter my shop stays around 60-65 when using the fan (sparingly). This has always made me nervous as I spray CV. I have been giving some thought to switching to waterborne, maybe this is the time to do it. Thanks,
Kevin
1/27/15       #2: Spraying waterborne in the winter ...
Bart
I don't even know what checking is. At 60-65 you've got nothing to worry about w/WB. I'm in SoCal and it has been in the hi 40's and low 50's many times in my shop this winter and I've had no problems. Sure it takes longer to flash off and dry times are slower but no real issues. I've used GF WB finishes for almost 15yrs. All I do is warm the finish in hot water before spraying so it sprays nice and lays down.
I used to spray SW CV it's nice not to have use the catalyst and the solvent to clean up with and no off gassing. Nothing like opening up closed cabinet door and getting a face full of formaldehyde.
good luck
1/27/15       #3: Spraying waterborne in the winter ...
Keeping the finish in a warm box(old refrigerator with a small ceramic heater) along with your glue, epoxy and the like is a great idea. You can also simply stick the hole gallon in a 5 gallon bucket of warm water. Also make sure the object being sprayed is not cold.
1/27/15       #4: Spraying waterborne in the winter ...
nicko
when i turn off my fan in the winter i run a propane torpedo heater for about ten minutes to get the heat back up in my shop.
nicko
1/28/15       #5: Spraying waterborne in the winter ...
rick morehou Member
Good Stuff.
I have found that Problems occur when the substrate, Air and material are all different Temperatures......Food for Thought.... there is a big change between Pot and Surface..
Thanks Rick M
