Subject: Re: Adding 844 colorant
Adding 844 colorant
3/13/15
I know you can add 844 colorant to a wiping stain like Mohawk, but can you add it to their penetrating dye stains?
For both adding to dye and to wiping stain, what is the maximum amount of ounces to a quart can you add without having issues such as adhesion, muddy look, not drying, etc?
I have some pieces that need to go to that rich, deep, burgundy cherry color and Im trying to get a deeper base quicker and help eliminate multiple passes with the mohawk dye stain.
3/13/15       #2: Adding 844 colorant ...
joe
Mike,
you need to be careful when adding 844s to an existing stain, knowing the tint load on that particular stain would be helpful as most will have a max %. Aside from the muddy appearance you could run into adhesion problems. Not knowing the wood species that your working on your best bet is to get the deep tone down with a dye first them apply a stain over that. Or you could get it deep as possible with a stain then make a shader coat using the 844s/Dye Concentrates into your coating to achieve additional depth.
