Subject: Re: darkening dye
darkening dye
4/3/15
JeffM
I have mixed some aniline dye and it needs to be darker. Is there anything (black) that I can buy locally that will be compatible and darken the color. It is mixed in water. I would like to get it done this weekend so online is the last option. Will utc's mix in with dye? How about india ink?
4/3/15       #2: darkening dye ...
jimmy cream
Im not 100% sure , but I do believe Transtints are sold at a few retail places . can be mixed in alcohol or water .
4/3/15       #3: darkening dye ...
Jeff M
I'm pretty much limited to Lowe's and HD. No woodcraft or anything like it. What retail places are you talking about?
4/3/15       #4: darkening dye ...
Robert Member
How about a Black Rit laundry dye. Can be had at Safeway or Albertsons or Lucky or Walgreen's.
4/3/15       #5: darkening dye ...
jimmy cream
it wasnt a regular big-box........must have been a specialty shop .....possibly woodcraft as they carry transfast also
4/4/15       #6: darkening dye ...
nicko
I have used india ink from the art store. It will mix with water or you can use it straight out of the bottle. I have just wiped on india ink right out of the bottle.
there is a video on Charles Neal web site of him using india ink to stain a project.
good luck..................nicko
4/4/15       #7: darkening dye ...
Bob "Boardman" Borders Member
Dick Blick's India Ink. Can find it at Art Supply or Arts & Crafts stores
4/5/15       #8: darkening dye ...
JM
What about hitting the local paint shop and seeing if they will sell you a little of their tint?
4/5/15       #9: darkening dye ...
Mitch Suber
Website: http://subercustomshutters.com
How much darker are you talking about? Have you already tried mixing another batch using less water and the same amount or even more of the dye?
4/13/15       #10: darkening dye ...
Kyle
First, what species are you working with?
this will make all the difference in the world.
a little background goes a lot further than all the nickle & dime trips, - hunting snipe
4/14/15       #11: darkening dye ...
Jeff M
I guess my question was more of a chemistry one. I wanted to make sure I wasn't mixing things together that would cause bonding issues with the topcoat.
At any rate, I got the color I needed by using just SW wiping stain. Completely eliminated the dye step and a ton of work on around 60 pieces. The species was alder.
4/15/15       #12: darkening dye ...
RRM
Try using TransTint dyes with acetone. It will dry very quickly so you can re-apply. Trying to over-saturate your dye solution will cause dye to crystallize out or show blotch. I've re-applied 5-6 coats of acetone/dye and it's fast. Each coat will darken your color. Beware of adding black dye to make things darker, often it will just muddy the color; try using a darker tone of same color group or just apply several coats.
4/15/15       #13: darkening dye ...
RRM
Oh, one more thing. Spray it, don't try to brush it on.
