Subject: Re: Pre cat over cat
Pre cat over cat
4/25/15
Nick Cook Member
Website: http://www.cedarrivercabinetry.com
Hello,
I recently got white lacquer, tinted white from SW. It's a catalyzed product and I sprayed over the tinted coats with pre cat satin lacquer for the final coat. SW neglected to tell me the tinted lacquer was a catalyzed product. Would there be a problem long term with the finish?
The finish is a week old at this point and looks perfect.
4/25/15       #2: Pre cat over cat ...
Andrew J. Coholic  Member
Website: http://www.joecoholiccustomfurniture.com
In general, and there are always exceptions with specific brands...
You can usually spray a catalyzed product over another catalyzed product - and a non cat finish over a catalyzed finish but not the opposite.
Seeing as how you are shooting a pre catalyzed finish over a (you didnt specify pre or post cat for your colour) base which is catalyzed I would say you are OK.
If there will be a reaction, it will generally happen on the first or sometimes second coat, immediately after spraying while the finish is still wet. You get a wrinkled up or blistered finish, which is the more aggressive catalyzed finish attacking the weaker uncatalyzed finish that is already on.
4/26/15       #3: Pre cat over cat ...
mastercabman
Sounds like a pre-cat from SW
If it was post you would of know since you would have to catalyse it yourself
Pre cat over pre cat should be fine
4/26/15       #4: Pre cat over cat ...
Nick Cook Member
Hi Mastercabman,
The guy was catalyzing it after he tinted the
lacquer. It's supposed to have a pot life of 90 days or something. I'm always using it up in a few days. What's your opinion of SW lacquer? Do you have a favorite and why?Thanks
4/26/15       #5: Pre cat over cat ...
mastercabman
Right now my favorite is ML Campbell
I am right around the corner of a Wurth group and I have a good relation with the finish tech
But I do work with SW pre cat a lot
It's pretty good but I use the SW for touch ups and it blends really good
Whenever you get a finish that is catalyse at the store it's what we call pre cat
When you have to mix the acid yourself it's call post cat
Post cat usually have a pot life of 8 hours
As for pre cat(depend on brand)90-120 days
Some can get up to 6 months
But Mlc is my favorite for now
I like it better because I can get it right away
And I can deal with knowledgeable person
