Subject: Re: Help! Black spots on Cherry
7/19/15
Rich F
I'm soaking cherry in hot water to bend and I keep getting black spots on the wood. The tub is aluminum, there are no iron containing materials used in the process (as far as I can tell) so I'm baffled. I'm spending all of my time sanding out the spots. Any thoughts on prevention and/or removal once the spots are there?
7/19/15       #2: Help! Black spots on Cherry ...
ThomasFR
Oxalic acid. Useless for bleaching wood but nearly miraculous removing black(ish) & other stains, even cat pee!
7/19/15       #3: Help! Black spots on Cherry ...
Rich
Thanks Thomas, after your post I did a search and several sites confirmed your suggestion - just ordered some. Now I need to determine how to prevent the spots in the first place. Maybe add some oxalic acid to the hot water bath, might be worth a try.
7/20/15       #4: Help! Black spots on Cherry ...
Pat
It's common to have some iron in tap water, either naturally occurring or from the pipes. There are DIY testing kits that you can buy to check this.
7/20/15       #5: Help! Black spots on Cherry ...
John S  Member
While I agree that Oxalic acid is great stuff, I would be very cautious using it on American Black Cherry. If you do use it, be sure to cover the entire veneer face with it. Don't try to "blot" it on just the dark spots, or you will be sorry.
It doesn't happen on every Cherry flitch, but Oxalic acid often "reacts" with the acid and the treated areas will turn bright red (not a natural look at all). Putting a coat of finish on it makes it look far worse.
So experiment with what you have before you go "whole hog" with the acid.
7/20/15       #6: Help! Black spots on Cherry ...
Rich
Thanks John, I'll be real careful when I first try it.
Rich
7/20/15       #7: Help! Black spots on Cherry ...
Use distilled water, not tap. This time of year, use the condensation water from AC or dehumidifiers. Might save you $.90 per gallon, LOL.
7/21/15       #8: Help! Black spots on Cherry ...
Rich
Distiller water on my next batch.
Thanks!
