Subject: Re: Shopping for a spray booth
8/24/15
BRANDON FILZEN Member
I have recently expanded my shop and would like to move all of my finishing in house. I have begun the search for a spray booth and the options are overwhelming. I think I have narrowed it down to two booths: A semi downdraft Col-Met booth with infrared heaters, or a reverse down draft Ameri-cure booth with heated make up air. The A.C. booth seems to be a really good buy as they are running a special on it right now, but I have been unable to find any reviews on this brand. As for the Col-Met booth, I have no Idea if infrared heat is ideal for cabinet and door finishing. Please give your two cents.
8/25/15       #2: Shopping for a spray booth ...
chris
you will need heated make up air if you live in a cold part of the country.
It also depends on what you are spraying. water or solvent based.
