Subject: Re: Polisher Recommendation
9/1/15
Howard Member
Getting a little tired if buffing out wax by hand, and wax over shellac is becoming my go to finish where appropriate. Is there a good polisher/buffer that I could use that would not produce too much heat buildup?? Thanks for the help.
9/7/15       #2: Polisher Recommendation ...
buddy braun Member
I use a festool 150 rotex with sheepskin pad and foam pad for final buff. you can adjust the speed and it is an incredible sander. a
little pricey-but well worth it.
9/9/15       #3: Polisher Recommendation ...
chris
get something like a makita or dewalt with variable speed. around $200
9/27/15       #4: Polisher Recommendation ...
Dustin Member
Website: http://www.hardwoodflooringminneapolis.com
Festool makes white and green buffer type pads for their sanders.. I know they are available in 6", but they may have 5" too. These would be compatible with any hook and look style 6" palm sander.. They work great, we use them for applying hardwood oils to wood stair treads and risers, deck railings and stairs etc.. Hope this helps.
