Subject: Re: Full finish Kemvar
Full finish Kemvar
12/8/15
Ed  Member
Website: http://www.thespeedofwood.com
Is there anything I can use on stained red oak to do a full fill grain finish, under SW SHER-WOODŽ Water White Conversion Varnish? Nothing is stained yet, so I'm open to all possible solutions.
12/8/15       #2: Full finish Kemvar ...
shenendoah
2 things at least:
1. get some grain filler (sw has), mix it with your stain and apply per directions. expect to do it twice. expect to apply multiple sealer and top coats.
2. apply 2K pu barrier coat reduced 50% +. one can then apply polyester until fill is achieved. note: polyester coatings should start off reduced 50% + with acetone and finish off with less reduced coatings in order to achieve fill with minimal pinholes. final coating with your desired topcoat. one can still use grain filler with this system, though the polyester essentially replaces that step.
12/9/15       #3: Full finish Kemvar ...
Kevin
my options would be exactly as shanendoah outlined.
