Subject: Re: Colron Indian Rosewood Wood Dye
1/16/16
Alan Member
I have a tin probably 15 years old with a small amount of Colron Indian Rosewood wood dye. It performs great on some english cherry after sealing it with some acrylic water based mdf sealer and lightly sanding, followed by Shellac sealer, polish and wax. Unfortunately the old Colron dyes are not available anymore, probably due to VOC regulations. I think the very effective but now extinct range of Colron dyes were spirit dyes, though I am not sure what the actual solvent was, quite a strong smell and not very fast drying. How can I best reproduce this with professional products from currently available suppliers like Morrells, Mylands, Jenkins or Symphony in the UK?
1/17/16       #3: Colron Indian Rosewood Wood Dye ...
Brian Cummins
Hello Alan
Are you in the UK? If you are, Morrells will make an exact match of any colour you want. Ring their technical department in Stockport (0161 406 5300) for advice. I've used them for more than 30 years, and never been disappointed.
1/17/16       #4: Colron Indian Rosewood Wood Dye ...
Alan Member
Thank you, yes, there is a branch not too far away. Will do.
1/18/16       #5: Colron Indian Rosewood Wood Dye ...
Alan Member
I had a similar response from both Symphony Coatings and Morrells which was that they can only mix up water or meth based stains which isn't going to give me the result I need. It would appear that the old Colron stains were oil based. Fiddes make oil based stains, mainly for furniture restorers, as it's especially good under shellac finishes, as the meth in the shellac doesn't draw it out. It is available in 1L and 5L quantities so a custom mix of those should get the job done.
1/19/16       #6: Colron Indian Rosewood Wood Dye ...
Robert Member
Might be a long shot Alan but have you checked out.. WD Lockwood Co ?
1/19/16       #7: Colron Indian Rosewood Wood Dye ...
Alan Member
Thank you Robert. Lockwood probably do stock the type of stain, but they are in the US and I am in the UK. There are several stockists here who stock the Fiddes range of oil stains, easily found with Google. I have ordered some red mahogany from AG Woodcare and my polisher friend has brown mahogany and some other colours to make a mix from.
