Subject: Re: Finishing
Finishing
5/27/16
Brad Member
I am looking for an exterior top coat that I can spray on a sign. The MDO board was primed and then painted with acrylics. The sign will be exposed to the weather. Product? Procedure? Thanks.
5/30/16       #2: Finishing ...
nick
Target 9300 might work, It is crystal clear and rated for exterior work and I've used it for the same application you're doing with success but why I say "might work" is; anytime you apply a harder finish over a softer more flexible coating you risk the possibility of the top coat crazing (thousands of tiny hairline cracks). to be on the safe side I would try it first on a test board painted with your sign paints to make sure it will work. Let your sign paint dry/cure well before applying the clear, at least 48 hours, more time would be better.
Any spray gun would work...I'd use a gravity gun with a 1.2 to 1.4 nozzle.
