Subject: Re: SHER-WOOD SB STAIN under conversion varnish
5/30/16
antonio
Website: http://www.positivewoodworks.com
Have any of you used sherwin williams sb stain with clear conversion varnish as a topcoat? trying to find out how compatible they are as a system?
5/31/16       #2: SHER-WOOD SB STAIN under conversion ...
Alan
I do it all the time. No problems. As long as you reduce the stain concentrate properly. Some people use it straight. Not recommended. Use proper reducers and some clear stain base and allow a few minutes flash off time. I use a vinyl sealer, scuff, then topcoat conversion varnish. No problems.
