Subject: Re: Kremlin temperature sensitive?
6/28/16
Michael Horrillo
We moved the shop and I was all jazzed about installing a refrigerated air drier at my compressor. We started running air randoms and did not want the things to get flooded out with condensation from the air lines. Went to final a few bathroom vanities before going home tonight and my 10-14 started acting like the whip end of the feed hose to the gun was clogged. Snaked it out with piano wire and the pump would only start with 90 psi into the air motor. Cleaned the whole system out several times and still the same problem, even with running pure acetone threw the system. Put my hand on the top cap of the pump and noticed that it was extremely cold? As a last resort I shut off the air drier and once the cap warmed up, it was back to my old perfect finish 10-14? I had a similar problem years ago when I tried to warm up my lacquer with a drum heater in the dead of winter. Any thoughts, or maybe I should have gone home early!
6/29/16       #2: Kremlin temperature sensitive? ...
chris
how close is the drier to the kremlin?
you might need to add more air line to the run to allow air to warm up.
did you size the drier to size of compressor?
I have a refrigerated drier on my system but have never had these problems with my kremlin.
6/29/16       #3: Kremlin temperature sensitive? ...
Michael Horrillo
Thank you!
The drier is a little undersized for the 10 hp/100 gal compressor. The booth is about 75 ' of air line in on the system. The only thing I can think of is that the pump has a max. and a min. temperature
efficiency range.
6/29/16       #4: Kremlin temperature sensitive? ...
herb johonson
Air is a gas and gases will get hot when they are compressed and cool rapidly as they expand.
Air motors use compressed air at 20 to 180 psi (1.4 to 12.4 bar) and exhaust the same air at approximately 14.7 psi (1.0 bar) or atmospheric pressure. This is an extremely high percentage pressure decrease that
occurs in a short period of time. Exhaust air temperatures will be well below freezing on
exit. Moisture in the air freezes and crystallizes at these low temperatures. This is the
same basic principle as household refrigerators.
Icing is a problem that is inherent to all air motors. Many factors can influence icing.
They include:
Compressed air temperature.
Compressed air dew point.
Compressed air pressure.
Compressed air volume flow rate.
Air quality due to contaminants.
Ambient air temperature.
Ambient air dew point.
Ambient air flow.
Motor air valve material.
Motor air valve geometry.
Cycle rate of motor.
Exhaust port restrictions such as a muffler.
