Subject: Re: Curly Maple Mantle piece
8/21/16
KEN CULBERTSON Member
Have a really nice piece of curly maple beam that will be used a mantle. It is highly figure, and has some spalting caused by the ambrosia beetle. So am wanting to know the best best finish that would pop out the curly part of the wood.
8/22/16       #2: Curly Maple Mantle piece ...
Dan cook
Use a dye first even if it is a light colored dye. Dye, not stain, tends to really bring out the curl. If you are using clear satin for your finish, put on several coats of clear gloss first and then use your satin only on the last coat. Satin has stearates in it that will tend to cloud the finish when multiple coats are applied.
8/22/16       #3: Curly Maple Mantle piece ...
RobertJ
BLO is sometimes used first.
8/22/16       #4: Curly Maple Mantle piece ...
You say us BLO then what is next.
8/22/16       #5: Curly Maple Mantle piece ...
Which dye would be used.
8/22/16       #6: Curly Maple Mantle piece ...
RobertJ
If you don't want to use BLO (Boiled Linseed Oil) try a clear stain base (MLC or SW) followed by Conversion Varnish.
If you choose to use BLO, allow to dry.....48-96 Hours, followed by vinyl sealer, then top coat with any finish you may want...pre or post cat lacquer or conversion varnish, or 2K Urethane.
8/22/16       #7: Curly Maple Mantle piece ...
Bart
Shellac looks great as does an amber dye. General Finish or Transtint dyes work great. You could even use nitro and let it amber slowly as will a good poly-varnish or marine varnish. You could mix up a solution of solvent/poly and thinner and hand apply multiple coats. I did a project for myself on some highly figured birdseye veneers and used shellac flakes for the first time and top coated it with GF WB. It really brought/popped out the figure and has that nice "even" warm amber tone. Be careful to not use too much dye/color too fast or you can blotch it up pretty fast. Lighter is better. You can blow past a nice shade real quick.
my2cts
good luck
8/23/16       #8: Curly Maple Mantle piece ...
KEN CULBERTSON
Well thanks for the information on popping out the figuring on the curly maple. I will be spraying an aniline dye on the mantle piece followed by BLO. Both help enhance the figuring in the maple. Then look at what finish I will use on it. So any idea of what finish to put on, there are so many and I want to use what will make the best finish for the mantle piece.
8/26/16       #9: Curly Maple Mantle piece ...
james G
Ken , I like to use dye or wipe stain , .dye stain keeps the wood a little more vibrant . A combo of the 2 will help accent the grain even more . Dye first then wipe your stain over it .
What I have found to work very nice and give some contrast is to STRIKE your stain after it has dry for about 5 mins with acetone . What acetone will do for you is pull color from the top and leave it in the grain .
Fold your rag and wipe in even strokes , fold your rag after strikes to keep from introducing the washed stain back on to piece .
Repeat the whole process a few times if you'd like . Somewhere in there you might want to give the wood a chance to dry to scuff the grain down a little bit .. Light 320 will not hurt . Especially before final stain so grain isn't to raised before your seal coat . I like MLCampbell product . Krystal sealer is a post catalyzed conversion varnish sealer . Drys very fast and sands beautiful . Krystal post cat. top coat to your desired sheen . All their sheens are clear so the cloudy issue mentioned in earlier post isn't an issue . As well that Conversion Varnish is very resistant to moisture so if some one were to accidentally leave a glass /drink to sweat on it , it will not harm it like a lacquer would be affected .
Florida based , and would not even think about boiled linseed oil in my shop . To many fires started with that stuff soaked into rags down here .
