Subject: Re: Antique steel finish?
8/22/16
Andy Member
I am constructing a table with a thick wood top with a 1 1/2" "black pipe" structure. I want to achieve a dark antique finish, but I don't know how to go about it. I don't want any rust, just a variation from natural steel to dark antique.
I plan on stripping all the black paint off the pipe and possibly media blast the pieces.
8/22/16       #2: Antique steel finish? ...
kevin
Check out modern masters. Black patina. there are several others as well
Modern Masters
8/22/16       #3: Antique steel finish? ...
kevin
what you want to do is rub it in until your satisfied with the color change. then rinse it off and coat it to lock the color in and stop the "aging"
8/22/16       #4: Antique steel finish? ...
Cleaning the black pipe is going to be a real pain. That stuff is closer to tar than paint. IF you get it all off, you could use some gun blue or browning to color the steel. Or, do research on metal patina to see what chemicals give it different colors.
8/23/16       #5: Antique steel finish? ...
Pete D
As already mentioned look into patinas. I've used ones from sculpt nouveau and caswells, but there's many options and it's a bit of trial and error. The patina will generally be more consistent and uniform if the pieces can be submerged vs spraying or wiping on. Make sure the metal is bare and wipe down with a degreaser. As Kevin said, you rinse off after getting the desired effect then seal it with a clear coat. If it's not sealed it will rust. If you want to do more work like this and you can weld look into cold rolled or pickled and oiled tubing as they have no finish or mill scale.
