Subject: Re: Semi-gloss urethane gets to glossy
9/2/16
Dave Member
Website: http://davidmohringdesigns.webs.com
I have been HVLP spraying Varathane semi-gloss polyurethane on several projects over past years and have been getting sheen variations in the finish. Sometime the semi-gloss gets really glossy, other times its fine. Why is this? I make sure the can is well mixed always. Sometimes I spray in winter, sometimes in summer. Will humidity cause this?
9/3/16       #2: Semi-gloss urethane gets to glossy ...
Humidity will not change the sheen of urethane. You are using a cheap hobby quality finish, there must be changes in the flattening agent added in each batch.
9/4/16       #3: Semi-gloss urethane gets to glossy ...
JeffA
Temperature is a leading cause of gloss variation. When extreme heat and cold are prevalent, they can make your coatings react and cause these issues. When it is too warm, the coating will be lower in viscosity and the flattener will rise to the surface causing the gloss to be lower. The opposite is what happens when it's too cold, the viscosity is higher keeping the flattener from getting to the surface, making it higher in sheen.
9/6/16       #4: Semi-gloss urethane gets to glossy ...
Dave Member
Thanks for the responses. Can anyone recommend a high quality polyurethane that has better batch consistency and temperature range of application?
9/6/16       #5: Semi-gloss urethane gets to glossy ...
Dave Member
The problem I just had was when it was near 90 deg outside (my shop in not air conditioned). So according to Jeffs response I should be seeing less gloss, but I am getting more. Makes me think its the brand of varnish that has variation.
9/6/16       #6: Semi-gloss urethane gets to glossy ...
Steve Member
Dave, I am not a big fan of Varethane, just personal pref., but I am of Sherwin Williams Polyurethane, and it is available in gloss and satin. By mixing the two in varying proportions, you can determine any degree of sheen you desire.
9/8/16       #7: Semi-gloss urethane gets to glossy ...
Dave
Thanks Steve, I was going to go to Sherwin Williams next actually. How about the Deft product? I think its a PPG product.
9/8/16       #8: Semi-gloss urethane gets to glossy ...
Steve Member
If I am not mistaken, the Deft product is nitrocellulose Lacquer or some variation of it, sold as BRUSH ON because of it's conflict with prohibitive air quality spray regulations in most areas, and generally limited to quart quantities for that reason, e.g functionally limited to small application surface areas. In any event it certainly is not a Poly to my observations and test application. Check the can label for prominent BRUSH admonitions.
Whatever your difficulties were in the OP, this will propel you from the frying pan straight into the fire.
9/8/16       #9: Semi-gloss urethane gets to glossy ...
Deft is not a professional finish either. It is very soft and not that water resistant. Go to Sherwin Williams and buy from their PROFESSIONAL line of products!
