Subject: Re: Spray Booth
Spray Booth
11/15/16
scott
We are looking for a Semi Downdraft spray booth and possible have one available for $5000.00 about 10 years old. Possible bearing going out on main exhaust fan. It has no heated makeup. Does anyone use a heated unit we are in So Cal. but temp in fall and winter can get down below 50 in the am. for 6 of the months. What size heater for a 14 x 20' unit. Anything else I should know.
11/17/16       #2: Spray Booth ...
Scott,
You require a heater based on the cfm that your fan for your booth is removing. The size of the booth doesn't really matter that much, an open faced booth is usually designed for about 100 cfm per square foot of booth face opening. Just a ballpark for example a 24 inch fan removes about 6000-7000 cfm from your booth, so you need a make up air unit that is pumping in at least the same amount. You always want to run with a little bit of a positive pressure and that helps to keep contaminants from entering your booth when the door is open etc. The other important thing is you never want to put your building into a negative pressure or else it starts to suck all the carbon monoxide back into your building during the heating season which can be deadly.
11/18/16       #3: Spray Booth ...
scott
If I choose to forgo the heater , does the $5000.00 for the booth seem appropriate?
