Subject: Re: Rub Through
Rub Through
4/26/17
Jason
Hi I need some help from some experienced finishers. I have a small dilema. We painted a refrigerator panel white. It has trim pieces and now they want it painted black with a run through showing the raw wood. I told my boss that it would show some of the previous white paint. He told me not to strip it and figure it out. I have tried almost everything to hide the white that is showing through so I decided to come here for some help.
4/26/17       #2: Rub Through ...
Dave Edgerton  Member
you will have to clean off that white in the areas you want to show through, there is no way around it. strip it where you want the sand through and leave it white everywhere else. if you want stain to show through then stain those areas. Seal with a sealer, waterborne or whatever. Top coat with black PRIMER. Not topcoat. Then topcoat with clear.
4/26/17       #3: Rub Through ...
How hard is it to make a new paint grade refrigerator panel? Stop throwing labor hours at that one and throw it in the dumpster.
