Subject: Re: thinner vs retarder
thinner vs retarder
6/5/17
the google
please help me understand this. i've been having some issues with either micro bubbles or solvent pop.
so i have been spraying with <=5% retarder and getting decent results. the coat goes on and bubbles immediately appear, but they pop out within a couple minutes and everything is good. when i watch them pop out, the surface of the freshly sprayed coating is almost boiling, with bubbles popping very quickly. however, if i retard with more than 5%, the surface won't boil as much and most of the bubbles seem to remain.
so saturday i did some experimenting and wasn't having any luck with being able to get decent flow with only retarding 5% (or decent results with retarding more), so i switched from retarding to thinning. the results are night and day different, with thinning resulting in a much better, and without the boiling effect, finished product.
thinning, to my understanding, should be avoided on hot days, because it can cause the coating to dry quicker, and not provide enough time to allow the solvents to get out of the coating. retarding decreases the dry time and is generally recommended in warmer temperatures.
i'm spray ilva 2k urethane. saturday was 82* with 40% humidity. i'm spraying a kremilin aaa pump.
6/5/17       #2: thinner vs retarder ...
chris
I spray the same stuff.
i always use 20% thinner as per Ilva instructions. Very rarely do i have problems.
I'm in north east.
6/5/17       #3: thinner vs retarder ...
the google
chris,
so you thin with tz13? no retarder. i'd been using tz4223 as my retarder.
i'm assuming you're shooting from an aaa pump. what size tip are you using?
6/5/17       #4: thinner vs retarder ...
chris
yes I'm using a kremlin AAA.mostly use a 06-094.
just use TZ 13.
I'm spraying tables and mirror frames.
6/5/17       #5: thinner vs retarder ...
the google
chris,
we use it for tables.
are you using a box coat, or multiple passes, when you top coat?
i've used a 06, 09 and 12 tip and typically spray our table tops in two passes.
6/5/17       #6: thinner vs retarder ...
chris
i'd go with a 09 tip for larger flat surfaces
go with a box coat so you don't get any dry spots
6/6/17       #7: thinner vs retarder ...
Dan cook
What are you calling a box coat? Do you mean a crosshatch pattern double pass? I've not heard the term box coat before.
6/6/17       #8: thinner vs retarder ...
chris
dan. basically same thing
6/6/17       #9: thinner vs retarder ...
RobertJ
I would use the 09 tip as others have urged you to do. 06 is too small.
6/6/17       #10: thinner vs retarder ...
the google
i cannot seem to get the coating to come out fast enough with the 09 tip.
my hose is less than a month old and i have my fluid set to 30-35 lbs on a 20:1 kremlin pump. i use a micro-screen in the tip so that slows my flow a little bit.
6/6/17       #11: thinner vs retarder ...
chris
i don't use the screen just an o ring.
the screen at the bottom of the gun is enough
6/6/17       #12: thinner vs retarder ...
RobertJ
Follow Chris's advice!
6/6/17       #13: thinner vs retarder ...
chris
fluid pressure seems high
I have a kremlin 10-14 running at 35-40 psi
it's a 10-1 ratio
6/7/17       #14: thinner vs retarder ...
Jim Clark  Member
Website: http://s51.photobucket.com/albums/f386/jcquack/Fur...
Keep in mind, thinner comes in different
speeds, from fast dry to slow dry.
I personally quit using thinner (lacquer)
years ago and use auto grade
urethane reducer to thin my lacquers
and conversion varnish.
Much higher quality product.
Most lacquer thinners today are poor
quality, reconstituted junk, only good
for cleaning guns. If you find some good
thinner it's real expensive.
7/20/17       #15: thinner vs retarder ...
chris
still having problems?
just found an email from my ILVa supplier/tech.
he said to use TZ-425 starting at 3 ounces per gallon.
