Subject: Re: Spray System Cleaning Lacquer Thinner Good Price
3/25/18
Mike Member
I found 5 gallon Klean Strip lacquer thinner at Home Depot on sale right now for $62. They are only at certain Home Depot stores. Check online for location near you for supplies.
https://www.homedepot.com/p/Klean-Strip-5-gal-Lacquer-Thinner-CML170/
100173168
3/25/18       #2: Spray System Cleaning Lacquer Thinn ...
Bob
I buy medium grade thinner in 55 gallon drums for $250 delivered from a solvent distributor. Check with a auto body repair shop to find where they get their thinner.
3/25/18       #3: Spray System Cleaning Lacquer Thinn ...
bill stanisci
How do you safely store a 55 gallon drum of lacquer thinner? I had a cabinet shop neighbor with drums of lacquer and thinner in the building when it burned. No amount of water would put it out. Burned for hours and hours.
3/25/18       #4: Spray System Cleaning Lacquer Thinn ...
Jim Clark  Member
I buy 5 gal for $35.00 at my local auto
paint store.
3/25/18       #5: Spray System Cleaning Lacquer Thinn ...
Mike Member
Jim Clark, what brand of lacquer thinner is it for $35 a 5? I can buy cheap lacquer thinner or gun wash but I found better grade lacquer thinner cleans spray systems better and faster. I'm doing an experiment next week using the manufactures recommended thinner for their product.
3/26/18       #6: Spray System Cleaning Lacquer Thinn ...
Brian Member
If you use cheap thinner to clean with, you are potentially contaminating your equipment with whatever that solvent was used for before it was recycled. You are better off buying your coating manufacturer's recommended cleaning thinner, you are then staying within the "recommended system" and when there is an issue (and everyone will have an issue) you can exclude cheap wash thinner as a potential source of the trouble.
3/26/18       #7: Spray System Cleaning Lacquer Thinn ...
Mike Member
Brian, that is what I have been reading and is now my understanding. In the long run the expense is cheaper by using the products formulated thinner.
3/26/18       #8: Spray System Cleaning Lacquer Thinn ...
Mike,
Do you have some inside info that says that Klean Strip Laquer thinner from Homie Dopie is better or even good?
We get ours from our local Sherwin Williams store or a local pro Auto store(NAPA). Its in a proper can, not some consumer thing.
3/28/18       #9: Spray System Cleaning Lacquer Thinn ...
Jim Clark  Member
Mike:
It's not "gun wash" but it is a very cheap thinner. I mostly use it for only cleaning,
sometimes I use it in my sealer but for
regular finishes, lacquers or conversion
varnish I only use auto grade urethane
reducer. It works much better.
Good lacquer thinner is a rare thing.
3/28/18       #10: Spray System Cleaning Lacquer Thinn ...
Bob
Bill, I store the drums in a 20' storage shipping container on the exterior of my building.
