Subject: Re: Target EM 6500 pigmented
3/28/18
al
How does Target EM 6500 pigmented hold up for built-ins? Will their primer cover knots and brown streaks in birch plywood? Will they color match to a BM color? How many coats of primer and top coat using birch plywood, solid maple and mdf?
Thank you,
Al
3/29/18       #2: Target EM 6500 pigmented ...
Rob
I've used EM 6500 on several built-ins and never had any problems or call-backs. Haven't used their primer, I usually use BIN primer. Target color matches BM and SW.
3/29/18       #3: Target EM 6500 pigmented ...
Pat
It's now my standard product for pigmented jobs. The primer is not advertised as stain-blocking, but it does a decent job. It's super thick in the can, so you may have to thin it to get it to spray well. It doesn't sand as easily as the ML Campbell primer, but it seems tougher and fills grain better.
The 6500 is great to spray, rarely runs, and their color matching has been spot-on so far. The only downside is that the sheen is only available in satin, and it's a dull satin at that. I solve that by topcoating with EM 9300 with the sheen of my choice. The clearcoat also adds protection and improves the final appearance.
Once you've subscribed to their email, they're constantly offering discount codes typically good for 25% off.
Cheers,
Pat
4/6/18       #4: Target EM 6500 pigmented ...
al
Does the clear coat change the color?
4/6/18       #5: Target EM 6500 pigmented ...
Pat
Al,
I've been topcoating with the EM9300 and don't notice any color shift. However, they market the EM9000 as their "most clear" topcoat.
Cheers,
Pat
4/11/18       #6: Target EM 6500 pigmented ...
al
Pat,
What sheen do you topcoat with most often?
4/11/18       #7: Target EM 6500 pigmented ...
Pat
Satin. I've also done some in flat (which is not quite flat, still has a little sheen).
Cheers,
Pat
