Subject: Re: qualspray AM- 2012PR
5/15/18
Joe Member
does anyone have a AM-2012RP" reduced pressure" gun from qualspray, if so how do you like it.
5/16/18       #2: qualspray AM- 2012PR ...
Shane
Double check/price check online because I heard they are decent quality little packages but the qualspray is essentially just rebranded Asturo/AOM guns.... Several vendors carry the Asturo/AOM guns so you should be able to price shop..
5/17/18       #3: qualspray AM- 2012PR ...
mastercabman Member
Shane is right
It is very much like the Asturo
I have that Asturo
Good gun, powerful
It is rated low CFM but I feel like when I'm spraying my compressor (rolair vt25) has a hard time keeping up
My CAT'S just keep on spraying
5/31/18       #4: qualspray AM- 2012PR ...
Jeff Jewitt
Disclaimner--- I am the importer of QualSpray Equipment.
QualSpray is NOT rebranded Asturo. For a short time Asturo USA (after the Italian Asturo went bankrupt) and some QualSpray came out of the same factory in Taiwan. For their budget line, Asturo USA used a factory in China. Asturo USA is now out of business.
I'm not aware that Asturo ever had the AM-2012RP with Asturo on the handle. If they did it should be a black gun with a red retaining ring (which the factory uses to color code for RP)
As far as I know the only guns that were identical between QualSpray and Asturo were the following
AM-5008 (gravity)
AM-6008 (bottom feed)
H878 = QS-125WB (mini gravity detail gun.
