Subject: Re: Cup gun-efficient low overspray
6/5/18
Ed Arthur Member
Website: http://doorsbyinvision.com
What Is the most efficient (transfer efficient ) HVLC gun out there? I spray almost exclusively linear poly these days. I have a Kremlim 15:1 which is beautiful with a .06 tip but it actually uses more materials than needed.
Using just a cheapo Husky actually gives a beautiful finish but I want better transfer efficiency. Anyone using those powered cup guns? How are they for overspray?
6/5/18       #2: Cup gun-efficient low overspray ...
mastercabman Member
How much are you spraying?
If you are production then stick to AAA
6/5/18       #4: Cup gun-efficient low overspray ...
Ed Arthur Member
One entry door at a time. Vertically finished. Definitely not production. Airless and air assist have been my go-to method for over 45 years but I just think it’s overkill for the spraying I’m doing now.
6/5/18       #5: Cup gun-efficient low overspray ...
John Member
One door at a time here, too, or a few cabinets; a gallon in a day is a lot for me, but I often spray two or three different materials in a day. I use a bottom feed HVLP gun with a 3M H/O PPS cup on it. I've never measured the transfer efficiency but the manufacturer (Qualspray) claims at least 65%. It can't be that high for me because I usually leave the fan at max. width so I have a lot of losses when doing face frames, etc. The great part about this gun arrangement for me is the nearly no loss in finish when you clean up and how easy it is to clean the gun and cup. You don't even have to clean the disposable PPS cups if you don't want to; use them once and dispose. You also can store unused finish in them for quite awhile.
John
6/5/18       #6: Cup gun-efficient low overspray ...
nick
Rule # 1) When it comes to spraying there are no perfect solutions only compromises (I dare say rule #1 applies to everything).
Gravity gun set-ups are best at using every last drop of material. Buy a top quality Devilbiss, Iwata, Sata or Binks; I'm a Sata fiend but the Devilbiss Tekna Pro-lite is a fantastic spray gun...you won't be disappointed if you buy one!
when using pure pneumatic spray guns, getting better transfer efficiency is often up to the operator. Learn how to use the adjustments and options the gun offers and then use them and you should see a improvement in the amount of material you use and the quality of your job.
