Subject: Re: Pressure feed H2O Gun
6/12/19
Were going to be buying another gun spraying waterborne clears almost exclusively and leaning towards the C.A. H20-CPR Cat Pack but the options/research is a bit overwhelming. Hoping maybe some will have some input to help us lock it down?
Any input on alternate options would be welcome.
6/12/19       #2: Pressure feed H2O Gun ...
chris
how much do you spray a week?I am sure that most people would suggest you look into an AAA system if the volume justifies it.
6/13/19       #3: Pressure feed H2O Gun ...
Nick
In my experience the Devilbiss Compact or Tekna Prolite will give you a better finish and be more dependable than the CAT gun (yes, l own and have used all 3 extensively). Both these spray guns and parts for them are readily available in the USA.
That said, l spray my waterborne clears with a Sata 1000K RP; flawless finish, very dependable (built like a tank) but very spendy both the gun but especially the parts. They are a joy to use but not necessary.
6/13/19       #4: Pressure feed H2O Gun ...
I considered another pump but this gun likely wont see that much volume.
6/13/19       #5: Pressure feed H2O Gun ...
Gary
My go to set up every time
6/13/19       #6: Pressure feed H2O Gun ...
Thanks guys. At the price of the Sata we would just go with another pump. I didnt even want to spend the money on the C.A. and was looking at all sorts of options (other than cheap imports) from Graco Airpro on through. One rep is shipping me a low end Graco that he swears will be impressive but who knows. Have the C.A. on the way. We are not spraying at the level you pro finishers are but hate tossing away money. We will probaby wind up with a second pump eventually so for me Im not really inclined to spend nearly half the cost of an AAA rig on a gun.
6/13/19       #7: Pressure feed H2O Gun ...
Gary
C.A guns are great I have been using them for over 15 years, I have a Sata and Tekna Prolite, but always go to the C.A Technologies CPR
6/13/19       #8: Pressure feed H2O Gun ...
jonathan mahnken
if youre looking for occasional use, and cheap. I bought a pressure fed Iwata Air Gunza hte(made in Italy) for around 200 dollars and it sprays a pretty nice pattern. Im running it on an Iwata Dual Diaphragm Pump. They do feel a little cheap in some ways, but bang for the buck it would be hard to beat the finish.
