Subject: Re: Tinting polyester or urethane resin
11/2/19
Nick
A customer wants me to repair a 40 year old translucent black polyester resin bartop that a candle burned a 2" diameter × 1/2" deep hole in the polyester. I've done quite a few poured on bar/ table tops but l've never tinted one. Do l need to tint the polyester with 844 colorants or will universal tinting colors work?
11/3/19       #2: Tinting polyester or urethane resin ...
Bob Niemeyer  Member
NO and NO!! Polyester requires polyester based colorants.(opaque) If transparent some dyes will work but be carefull and test first.
PU can be tinted with 844's, but you sometimes will get a color that will "kick-out".
Best to use each manufacturers suggested colorant line for their products.
Any of the European coating Dist. that sells polyester will have the colorants you need.
Or try a fiberglass gel coat supplier(boats)
11/3/19       #3: Tinting polyester or urethane resin ...
Nick
Bob, thanks for the response!
One more question, l tint my epoxy filler for voids in slabs using graphite powder or coffee. Of course coffee won't work for this application but maybe the graphite will?
This bar top is at least 40 years old with cracks galore. The customer would love to have a seamless repair but understands close is better than a 2" hole
Also, l'm a believer in test and approved control samples before having at it.
11/3/19       #4: Tinting polyester or urethane resin ...
Bob Niemeyer  Member
Powdered Graphite should work as it is fairly inert. I have mixed all kinds of inert powders in polyester for weird effects.
The marble repair guys use polyester based glues. They also have available to them a full line of tints. Swing by a marble countertop fabricator and he might have some stuff you can tint with.
11/5/19       #5: Tinting polyester or urethane resin ...
Bart
Find a surfboard building supply company. You can get solid color pigments and tinted colors from any reputable company.
my2cts
cheers
