Subject: Re: Covering yellow poly on oak walls
8/26/20
Andy H
I have a customer with solid oak paneling on their walls. It has a light gray stain with 20+ year old poly on it. The wife wants to just paint it white, but the husband refuses to paint over the oak. I’m trying to come up with a compromise that doesn’t require a ton of labor. The wire isn’t in great health, so sanding the walls is possible.
Is there a way to achieve a white stain finish that would adhere to the existing finish, hide the yellowing, but still allow some wood grain to show through?
8/26/20       #2: Covering yellow poly on oak walls ...
Thinned white acrylic paint will stick to the poly. The bad thing is it dries very quickly, so wiping down quickly is a necessity. It will also be finicky for a consistent look over the entire wall. Good thing is that a quick wipe with a damp rag will clear off nearly all the paint off if it goes wrong.
8/30/20       #3: Covering yellow poly on oak walls ...
JeffA
Understanding the color wheel will help you. The opposite color of yellow is purple. But it turns a brown. And not always a nice color brown. This doesn't sound like an easy fix. I would just offer to paint over it but it sounds already you can't do that. Then walk away. I know that is hard to do. Sorry
