Subject: Re: Spray Booth Timer
Spray Booth Timer
8/9/21
Brendol
Website: https://www.houzz.com/pro/brendol-scholz/creative-...
Currently we have just an on/off switch for our booth. When we're done finishing for the day, I'm usually around for an hour or so after and leave the booth run to exaust fumes. When I'm not, the fumes in the shop are bad the next morning.
I've been searching online, but cannot find a timer for paint booths.
What options are there?
8/9/21       #2: Spray Booth Timer ...
rich c
You'll have to tell us what hp, single or 3 phase, and where you want it located. Something a fare distance from the booth will make it much simpler. At a safe distance you can go with a small digital timer and relay.
8/10/21       #3: Spray Booth Timer ...
Any small timer that can control a 120v load will work in conjunction with a contactor rated for the load of the fan with a 120v coil. You can have a small single phase timer connected to a 3 contact contactor to control a 3 phase fan.
I have something similar controlling my 3HP, 3PH fan, except my contactor is connected to a remote control to turn the fan on and off. It would be no different than having a timer control the contactor.
If all you have is a single phase fan you would need a 2 contact contactor.
8/18/21       #4: Spray Booth Timer ...
Brendol  Member
Single phase, 240v.
