Rotary polisher
1/3/15
I'm looking for a quality rotary buffer to put a high gloss mirror finish on dining room table tops.
Who's would you recommend and why? What are the key features i want to look for?
Thx
1/4/15       #2: Rotary polisher ...
jim
Sorry I don't have a good answer, but I remember hearing that the rpm speed is critical. They said not to exceed a certain rpm.
So for those with experience, we will all enjoy that part of the answer also. Thanks
1/5/15       #3: Rotary polisher ...
Jim Clark  Member
Website: http://s51.photobucket.com/albums/f386/jcquack/Fur...
Here's what I've learned from car painting,
get a buffer with speed control and
variable trigger speed.
I have a Dewalt that has a speed control
that limits the final speed but more
importantly the trigger has variable control
so you can start slowly then gradually
build up to your final set speed. that way
you don't sling the compound as much when you first start. I usually buff at about
1800 RPM for wool pads and a little faster
for foam. Everyone has different preferences.
Too many variables to make a suggestion.
1/5/15       #4: Rotary polisher ...
Jim russell Member
I have a Dewalt how do you know what rpm you are at. Thanks
1/5/15       #5: Rotary polisher ...
Robert Member
Makita makes a nice unit. Variable speed dial shows you what speed your using. Nice carrying case too.
1/5/15       #6: Rotary polisher ...
Denny J
I would look into one of the Gem sanders like they use in solid surface fabrication.
1/6/15       #7: Rotary polisher ...
Jim Clark  Member
The speed is marked on the adjustment dial just like the Makita.
I may replace my Dewalt with a Makita
when it wears out, I hear the Makita is
quieter, and it's a quality tool.
1/7/15       #8: Rotary polisher ...
Still Looking.... Member
But ain't no one gonna tell us a rpm speed are you?
1/7/15       #9: Rotary polisher ...
chris
found this article.
Buffing-with-paste-and-liquid-compounds
1/8/15       #10: Rotary polisher ...
Jim Clark  Member
Like I said, 1800 RPM
1/8/15       #11: Rotary polisher ...
Rick Mosher
It would be impossible to give an RPM without knowing what the coating is and the compound. You are not going to buff polyester the same way you would lacquer.
I always use a wool pad for compounding and then switch to a foam pad for glazing. The foam pads heat up much faster so they can be used at a slower RPM in general or else spritz them with water to keep them cooler.
For 2k urethane I am around the 1400 to 2000 mark depending on the sanding scratches. (I try to use nothing coarser than 1500 but sometimes I have to resort to 1200) Lacquer burns very easy so that would be a lower speed.
