Tinted lacquer finish
1/10/15
Nick Cook Member
Website: http://www.cedarrivercabinetry.com
I have an Alder sample with a stain that looks applied on top of the wood rather than
penetrating into the wood. It looks like stain
mixed into lacquer and sprayed on top. Can I tint lacquer with stain? I use tinted lacquer
to imitate paint currently.
Thanks for any responses.
1/11/15       #2: Tinted lacquer finish ...
You would more successful with help if you posted this in the finishing section. If by stain you mean dumping Minwax into lacquer, then no you can't. If you mean a universal colorant, or universal tint, then yes you can. It could be sprayed dye, or even toner. Post a picture in the finishing section for the best help.
1/11/15       #3: Tinted lacquer finish ...
james mcgrew Member
Website: http://mcgrewwoodwork.com
Tinting Laquer is common, we also seal, sand and "Tint" (Airbrush) the color after the seal. then top coats. materials need to be compatible to each other for this
But not with minwax............
