finishing high moisture content wood
1/15/15
doug mclaren  Member
i have been asked to quote all the bar top, table top, and bench top finishes in a new bar. all are 3 inch thick live edge slabs of hemlock fir. finish needs to be water and alcohol proof, i can wax and buff also. problem is when i picked up my samples all metered between 25 and 30+ percent. sawmill says they finish these tops all the time with a product called "permachink"? i never heard of it? 30 years of experience says this wont work? any advice or experience out there in the woodweb world? thanks . dhm
1/16/15       #2: finishing high moisture content woo ...
I'd stay away from that job. There will be lots of blame going around when the wet slabs start splitting and cupping. Likely they will blame the finish guy first since people seem to think that finish is supposed to encapsulate the wood and render it stable.
1/18/15       #3: finishing high moisture content woo ...
Brian T
I would recommend having the slabs dried in a Kiln before finishing and explain why to the owners. They may thank you for your input. If they don't then walk away.
1/18/15       #4: finishing high moisture content woo ...
jimmy cream
I just turned down a small wainscoat job made from log siding which would come at 18%......clear lacquer was the request .
permachink is a product line for log home exterior maintenance . may be what you're looking for when a film finish is not appropriate .
1/20/15       #5: finishing high moisture content woo ...
Rick Mosher
You can't use any film forming finish on them. I was told to do it one time against my better judgment and got water bubbles in the finish a month later. They were kind of cool though, it was like popping zits. The whole thing had to be stripped and allowed to dry before I could re-finish it.
