old Graco Turbine unit need advice
1/15/15
bobby Member
I had a decent turbine unit go bad and quickly bought a use Graco 700 turbine unit which worked fine. I have a deadline and it looked like it was going to help out but today it suddenly started making a lound noise and the pressure goes up and down but there is air coming out of it. Maybe somebody had one of the these units back in the day and can suggest to me a fix for this as time is running out. I also have a big compressor and hose etc but am not sure what I can get that might work--I will be spraying thinned latex on a cabinet casing and some doors etc.
There is a Northern Tool here, I have a tiny Harbor Freight hvlp cupgun which I shoot shellac through --I can get General Finishes HP Waterbase Clear to run through that-sort of.
Thank you
Bobby
1/17/15       #2: old Graco Turbine unit need advice ...
DCS
Bobby,
Not familiar with graco systems, but a coomon problem with turbine systems is the excessive heat the generate, which causes metal expansion inside the turbine. If this happens there is little that can be done to fix it.... Does the noise sound like the blades on the turbine are scraping on the housing of the turbine? If so, the units days are numbered....
DCS
