Target coatings pigmented lacquer
2/20/15
al
Anyone using Target pigmented lacquer? According to their website the primer that they sell
to be used with the pigmented lacquer does a great job covering the grain in poplar.
The primer is their HSF5000.
Looking for feedback,
Al
2/21/15       #2: Target coatings pigmented lacquer ...
Eric Doherty  Member
I use Target's pigmented lacquer with good results. I'm not looking to hide the grain, so I prime with BIN. I've never tried the Target primer, but have used most of their other products, all with good results.
2/22/15       #3: Target coatings pigmented lacquer ...
Nick
I've used it with good results, mostly to fill the grain when refinishing oak cabinets (when going from a clear to a pigmented finish). 2 coats does a pretty good job of filling the grain it also sands great. Be forewarned, it does leave behind a pile of sanding dust (like most surfacing primers) so I'd recommend a vacuum sanding system, especially if you're on-site. Sanding with 220/280 will give you a smooth, mostly uniform surface...perfect for applying finish to.
