sprayers/what to buy
2/27/15
tom Member
For doing fine finishes which is better.
Airless sprayer or air assisted.Will be spraying cabinets and fine furniture
2/27/15       #2: sprayers/what to buy ...
Mike Fuson
Airless is meant for spraying walls in houses. A lot of material at high pressure, not suitable for fine finishes. I don't have any experience with the AAA but many will tell you to go that way and may be right. I use a pressure pot with a Binks 95 gun, and have for years with good results. When I just have a few pieces to spray I use a gravity cup gun. This is one of those things that you get what you pay for.
2/27/15       #4: sprayers/what to buy ...
david bandy
tom a air assisted airless spray gun is the best gun for you spraying cabinets /or furniture
2/27/15       #5: sprayers/what to buy ...
Shane
You need to weigh out your options. If you are spraying finish all day it's a no brainer to go AAA just with transfer efficiency and paint savings. It will pay for itself very quickly. If your cranking up the pump once a week or once a month it's just a really nice toy..... we all love toys and the finish that can be achieved with an air assisted airless, your chemicals and shop conditions is ultimate perfection if done correctly. If you are set up clean and your topcoats solvents are tailored correctly you can spray out something quickly with the volume aaa puts out and everything will lay out nice and flat... no orange peel and dry spray junk like a pressure pot or cup gun that doesn't have the output as fast... A really good iwata gravity feed HVLP gun would be an option if you don't want to spend a couple grand for an AAA setup.. heck even a few of them would be handy with a quick change cup set up... keep them clean and they leave beautiful finish quality.
2/28/15       #6: sprayers/what to buy ...
Nick Member
Like the other posts said...it really depends on what and how much your spraying. I spray everyday, all day and I own damn near every kind of spray equipment...airless, AAA,
pots & guns, turbine and gravity guns, each set-up has it's place.
For spraying clear on a big cabinet job in the booth the AAA is the way to go, for clear on furniture or staining, dyeing or toning/shading anything I like the pot & gun or gravity gun (I have found nothing that will match the quality of finish that a top quality spray gun set-up can put out {pot/gun or gravity}) for house paint the airless is the ticket, for on site I usually take the turbine but if it's a big job I'll bring along the AAA instead, for samples, small jobs and touch-ups gravity guns are great.
