System 12 water based polyurethane?
3/4/15
Working on a Gov't job where the Architect has spec'ed out System 12 polyurethane water based satin finish. Anybody have a clue about this? Nothing out or google.
3/4/15       #2: System 12 water based polyurethane? ...
shenendoah
It is ok ask the specifier
3/4/15       #3: System 12 water based polyurethane? ...
CraigM
Could it be system3? I used this stuff to make samples once, that was as far as it went so I can't speak to how it holds up. I recall that it was easy to spray and laid out nice, but was very expensive
http://www.systemthree.com/store/pc/WR-LPU-Topcoat-c29.htm
System3 WR-LPU
3/5/15       #4: System 12 water based polyurethane? ...
Kevin
that is not a brand name... that is the system listed in the Architectural Woodwork Standards.
1.2.13.8 These standards recognize and offer guidance for the following finishing systems for both transparent
or opaque applications, unless otherwise indicated:
1.2.13.8.1 SYSTEM - 1, LACQUER, NITROCELLULOSE
1.2.13.8.2 SYSTEM - 2, LACQUER, PRECATALYZED
1.2.13.8.3 SYSTEM - 3, LACQUER, POSTCATALYZED
1.2.13.8.4 SYSTEM - 4, LATEX ACRYLIC, WATER-BASED
1.2.13.8.5 SYSTEM - 5, VARNISH, CONVERSION
1.2.13.8.6 SYSTEM - 6, OIL, SYNTHETIC PENETRATING (available in transparent only)
1.2.13.8.7 SYSTEM - 7, VINYL, CATALYZED
1.2.13.8.8 SYSTEM - 8, ACRYLIC CROSS LINKING, WATER-BASED
1.2.13.8.9 SYSTEM - 9, UV CURABLE, ACRYLATED EPOXY, POLYESTER or URETHANE
1.2.13.8.10 SYSTEM - 10, UV CURABLE, WATER-BASED
1.2.13.8.11 SYSTEM - 11, POLYURETHANE, CATALYZED
1.2.13.8.12 SYSTEM - 12, POLYURETHANE, WATER-BASED
1.2.13.8.13 SYSTEM - 13, POLYESTER, CATALYZED
3/5/15       #5: System 12 water based polyurethane? ...
Kevin
basically, you should refer to your AWS manual in Section 5 - Finishing (Page 3 of 19). If you have not become familiar with it yet, and plan on/currently are doing work for government or commercial clients, it would be a good idea to give it a look. You can use any brand youd like but what he is asking you is to stick to system 12. Water based poly. Satin sheen.
3/5/15       #6: System 12 water based polyurethane? ...
Thank you Kevin.
I appreciate your knowledge and help.
