Oil Paint over Conversion Varnish
3/14/15
James
I have some doors that are ready to be painted. The paint specified to be used is oil paint from Sherwin Williams. I also have several cans of non catalyzed conversion varnish that need to be used. Is it possible to use this under the final coat of oil paint. Conversion varnish is harder than oil paint so no issues there. My assumption I should be fine, would like to here other opinions. We also sand between all coats. Thanks!
3/14/15       #2: Oil Paint over Conversion Varnish ...
Kevin
my question is why screw with the oil paint at all? Get the color id # and have sherwin williams match it in a kemvar conversion varnish. There is absolutely no benefit to using oil based paint instead of conversion varnish.
However, there should be no issue with using an oil based paint over the cv. BUT i would definitely let that cv cure real good before using the oil.. cv off-gassing could cause problems.
