What are you using to spray water based paints and finishes?
3/23/15
Tom Member
I've been struggling with water based products for about 3 years now and am beginning to loose hope for these products. I've switched brands of finishes many times and I've tried a couple different spray systems, but I'm rarely able to get a nice finish without a large amount of hassle. So I'm wondering what everyone else is having success with? I've tried a cheap HVLP gun and I'm currently using a Kremlin 10.14 pump with a Kremlin MVX gun. I've heard Kremlin makes a pump thats designed more for water based finishes, I believe it was the EOS 15-C25, has anyone tried it? OR how about the CAT Technoligies H2O setup? I'm just very discouraged with the Kremlin system because parts are so expensive, hard to get and you can't find much information on them.
3/23/15       #2: What are you using to spray water b ...
Nick
I switched from using a 10:1 AAA set-up to using a pot and gun for spraying WB clears (WB pigmented lacquer too) and haven't looked backed.
With about half of my work spec-ed WB I decided to embrace the pot/gun after trying one out on a small job and getting great results instead of the often frustrating and less then satisfactory results I had with the pump.
Yes, a pot/gun can be a bit more work, use a lot more air and be a bit slower when compared to a pump (I use Sata 1000K guns with a 1.3 for clears and they are almost as fast as a AAA with a 411). but I've found the mostly drama free results to be worth it.
3/24/15       #3: What are you using to spray water b ...
RobertJ
With the Kremlin have you changed over to their 'waterborne' series of tips ending in the numbert 2?
They have worked for me to spray alot of Zenith Valspar clear and ICA clears.
If it's a small project, I use a gravity spray gun from CAT/Jaguar. Very happy. 1.4 or 1.5 orifice
3/24/15       #4: What are you using to spray water b ...
RobertJ
Use the following chart from Kremlin to choose the best tip size for your project
Airmix Tip Chart
3/24/15       #5: What are you using to spray water b ...
Tom Member
Nick: do you get a lot more overspray using a pressure pot system compared to a AAA, I think the only thing I've ever sprayed with one is contact adhesive.
RobertJ: I was aware that some tips were designed more for atomizing water based, but I didn't know they end in a 2. I've been using a 09-094+, but I do have a 09-112, I'll give that a try and see how it works.
3/26/15       #6: What are you using to spray water b ...
Denny J
You can get great results using any of the equipment you listed. I have been spraying WB for sneaking up on 2 decades and have tried myriads of different finishes and different sprayers. Once you understand the properties of WB you can use about anything. In my arsenal you will find everything from cheap Harbor freight cup guns topped with PPS cups to a turbine, airless and a few AAA units.
If I had to pick one sprayer for high volume clears, I really like the Graco Merkur AAA setup. Very quiet. Fantastic spray pattern and parts are only slightly astronomically priced.
For ease of changeover and anything less than high volume I would get a quality turbine unit and put an accuspray 10GP gun on it and add PPS. This is actually the gun that I can get the highest quality finish off but it is not as fast as the AAA.With WB I think you will find the accuspray to be the best best to a quality finish.
3/27/15       #7: What are you using to spray water b ...
jim
Denny, have you also used the apollo and fuji top quality guns? But still prefer the accuspray?
