Sherwin Williams white conversion varnish
4/16/15
al
I use Conestoga's finishes often to match doors I buy from them. They use Sherwin Williams CV. I would
like to thin it down a little. On SW info page they say small amount can be added to clear coats but are a little vague on pigmented CV. Butyl acetate seems to be the correct thinner but #100 naptha is also
mentioned but won't be compliant. I think the naptha would be my better choice but I am concerned if
it will do anything to a white finish.
Any info appreciated,
Al
4/16/15       #2: Sherwin Williams white conversion v ...
Kevin
kemvar white conversion varnish should be reduced 50% with Kemvar Solvent R7K310 ...
I use premium lacquer thinner sometimes too.
4/16/15       #3: Sherwin Williams white conversion v ...
Kevin
type in H66W51 in the product search below to review the data sheet
4/16/15       #4: Sherwin Williams white conversion v ...
Kevin
http://www.sherlink.com/sher-link/order/featureDisplay.do;jsessionid=gXoWpeH9ImUAn
GIQP8sktw**.ecommServer4
4/17/15       #5: Sherwin Williams white conversion v ...
Jim Clark  Member
Website: http://s51.photobucket.com/albums/f386/jcquack/Fur...
Let me tell you about thinning,
I use Auto grade "Urethane Reducer"
It works better than lacquer thinner.
Most lacquer thinners are low grade
these days with recycled solvents to
keep them cheap. Urethane reducers
are much higher grade and work much
better. The place I buy my auto clearcoat
recommend I use reducer.
4/17/15       #6: Sherwin Williams white conversion v ...
Kevin
ohhh boyyyy.....
4/17/15       #7: Sherwin Williams white conversion v ...
Jim
Jim Clark
Are you saying you are putting "urethane reducer" in (solvent) CV and pre and post cat lacqures?
I know I am expanding what you said .....just asking?
4/17/15       #8: Sherwin Williams white conversion v ...
Jim Clark  Member
Yes, that's correct.
I was told to do that by the owner/founder
of SPI auto paints, He's a chemist that's
formulated his own clearcoat and is quite
knowledgeable about coatings.
I wouldn't have trusted it on my own.
It is more expensive, but for the little
it takes, I think it's worth it.
4/17/15       #9: Sherwin Williams white conversion v ...
Jim
Thanks Jim Clark!
Time to experiment......
4/17/15       #10: Sherwin Williams white conversion v ...
Mark V.
Al,
Are you talking about Conestoga's Colortones or some other pigmented CV product that I don't know about?
Mark
4/17/15       #11: Sherwin Williams white conversion v ...
al
Yes colortones. It's made by Sherwin Williams but in Conestoga info it doesn't say anything about thinning. I don't need to add much thinner maybe 5 to 10 % to make it spray nice.
4/17/15       #12: Sherwin Williams white conversion v ...
Mark V.
Ok.
I'm pretty sure that it is a catalyzed primer and not a CV. You cannot leave it alone without a topcoat (CV) and old dried finish dissolves relatively easy with solvent, at least in my experience.
I have thinned it with regular lacquer thinner and acetone with no ill effects. I have probably used xylene too, but it would have been a while ago, so it might have been their Valspar finishes that were replaced with the SW.
I hope this helps.
Mark
Btw, I don't remember where I got them, but I have the SW product data sheets for Conestoga's CV and Sealer in pdf's. If you need them, email me and I will gladly send them to you.
4/18/15       #13: Sherwin Williams white conversion v ...
al
Yes that is correct it needs the topcoat. I will send you an email.
