Refinishing reclaimed teak
4/24/15
Colin Member
About 10 years ago I bought some reclaimed teak boards from Bali to use as shelving in my house. They are probably decades old, with a dark brown, naturally-weathered appearance. Unfortunately, over several years they were probably on the receiving end of various inappropriate home cleaning solutions. Having stashed them under a bed after moving house a few years ago, I've found some have now completely lost their finish on the surfaces where they were "cleaned". I'm attaching some pictures of damaged and undamaged boards.
Can someone suggest how I might refinish so that they approximate their original appearance? I prefer the original rough texture so I'd prefer not to sand, but I suppose I could always wire brush the distress back in if necessary....
View higher quality, full size image (2500 X 3764)
4/24/15       #2: Refinishing reclaimed teak ...
Kevin
teak oil... or messmers uv plus
4/24/15       #3: Refinishing reclaimed teak ...
Nick Member
oxalic acid wash, carefully and evenly pressure wash, allow to dry for at least week for the moisture level in the wood to drop to an acceptable level, apply a couple or three coats of teak oil
5/30/15       #4: Refinishing reclaimed teak ...
RRM
I have no good idea what "teak oil" really is, but as I've dealt with a large amount of teak, after bleaching, I prefer tung oil or a tung oil varnish. As I also make outdoor furniture and have done a lot of brightwork, I would use a tung oil varnish unless the customer is diligent with re-application of real tung oil, not a "teak oil" which, I've found can be nearly anything.
