Klearvar sheen issue
5/11/15
JohnB Member
I am just finishing up a small job using MLC klearvar conv. varnish. The customer originally said they wanted a satin finish and as their kitchen cabinetry is WoodMode, they said it should be hand rubbed. I sprayed using satin sheen with final coat sanded w/400 and rubbed out with a very fine scothbrite type pad. I thought it looked great but after installing the 2 base cabinets, customer called and said they expected it to be a glossier look and felt it was an inferior finish as it didn't "shine" more. I have explained that it is a satin, handrubbed finish, but that if they want it "shinier" we can polish to a higher sheen, but they were told by a "more experience finisher" that it needs to be recoated with a semi-gloss coat instead. This is the first time I have ever been asked for a glossier finish on my cabinets as most want either a flat or satin, rubbed out. These are raised panel, beaded face frame cherry cabinets so a lot of nooks and cranies to buff so maybe re-coating makes sense if it were an off the gun finish but They still claim they want the hand-rubbed look. What route would any of you guys take? I've been spraying for 35 yrs, but outside of table tops, have not run into much semi-gloss looks. As most of my work is more Shaker style I've always leaned towards flatter finishes. This is keeping me awake hence the early morning posting!
5/11/15       #2: Klearvar sheen issue ...
Max Neu
Based on what they are wanting, I think you will have to respray.I would show them how shiny semi gloss really is before you recoat it.
