Clawlock II primer problems
5/16/15
Phil Burruss
We are in the south.I love clawlock II primer.because you can get by with one coat of primer. But i kept having problems when i spray the resistant on top.Wrinkling happens in places here and there. mostly on face plates. I have alreadly checked thickness, myself and rep. checked it.What is going on.Help
5/16/15       #2: Clawlock II primer problems ...
sean
Are you catalyzing both claw lock 2 and resistant 10 percent? Are you spraying resistant directly on the claw lock, or using a sealer in between? I've seen this before when the quick dry vinyl sealer is used in a conversion varnish system. Typically with stealth.
5/17/15       #3: Clawlock II primer problems ...
CWK
Spraying heavy, hot humid temps and thinning with lacquer thinner?
thin with butyl acetate instead.
5/17/15       #4: Clawlock II primer problems ...
Phil Burruss
no its been catalyzied exactly what it is supposed to be. Also its been doing this even when its not humid.The resistant wrinkles up and you can just rack it off to the bare wood.we have tried everything we know to do.
5/17/15       #5: Clawlock II primer problems ...
sean
How about dry time? Do you let the primer dry thoroughly before sanding and topcoating? If the catalyzed primer isn't allowed to dry and cure out, there can be issues with wrinkling.
