mdf door panels -- 0 --
5/14
I made some doors to spray white. They are flat panel in the front and and a small scoop in the back with a flat face. All as I had was 3/4 inch mdf so when I ran them through the shaper to fit in my maple rails and styles the back was sticking up past my rails and styles witch I new would be the case. I ran them through my drum sander so everything is flush in the back the problem is now the back of the panel is very porous and I have started spraying them did not notice with the primer but did with the top coat I have sanded them back down so they are bare now what is the best way to fill the mdf panel so they are smooth. I am spraying them with white laquer primer and top coat
Pat
5/14 #2: mdf door panels ...
Just sand them down with a finer grit of paper….about 120-150 on the ROS should do. Also you may want to get yourself a nice bright light and put it to the side of your pieces where your spraying. Then you can check your panels after you get primer on there. Any defects should show in the primer where they're more easily addressed.
good luck,
JeffD
5/14 #3: mdf door panels ...
I would do as said above, but size the thickness better next time so you don't have to do this. Just undersize it so it never goes out of the frame. Once you break the face layer of MDF it paints very poorly. Sanding well with a high solids primer will help infill the sanded faces though.
5/15 #4: mdf door panels ...
I sanded them down to 320 will spray today and see how it goes thanks
5/15 #5: mdf door panels ...
Spray a primer that is designed for MDF. MLC's claw lock is one, there are other brands. I don't remember the exact #, but I think it is about 57% solids. It will help a lot with filling the porous MDF.
5/15 #6: mdf door panels ...
We always seal coat our MDF panels. It really helps to give a smooth coat of paint. Its well worth the extra step.
5/15 #7: mdf door panels ...
Phil
Are you referring to zinsser's seal coat?
5/16 #8: mdf door panels ...
shellac, don't leave home without it, it will work everytime 1.5Lb to 2.0Lb Cut..That is a seal coat. then a coat of Cover Stain. now finish
5/18 #9: mdf door panels ...
I spray any machined areas of the mdf panels with clear precat lacquer reduced 50% with lacquer thinner.
Sand the profiles on a Larick profile sander and dynabrade on the flats, prior to assembly.
Assemble, sand and finish with pigmented vynil sealer and topcoat with precat lacquer.
Results in a very smooth finish even on the profiled areas.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
