Pre-cat VS Post Cat
5/27/15
Joel
I have been using pre-cat laq for years without any problem but a post on another forum got me wondering. What is the difference between pre-cat and post-cat lacquers? The only time I don't use pre-cat is on table tops. There I have been using poly. Could I use a catalyzed lacquer and expect it to hold up on a high use surface? I know a lot of guys have switched to CV but I am very comfortable with spraying laq as it is pretty much idiot proof. Thanks for your input.
5/27/15       #2: Pre-cat VS Post Cat ...
Tim G
I also used precat for years, but noticed older jobs often had failure from typical water splashes. Once I started using CV for most everything, jobs I did years ago are still looking great.
5/27/15       #3: Pre-cat VS Post Cat ...
Jim Member
Is CV the same as catalyzed lacquer?
If so, how does it spray compared to pre cat? I have been using pre-cat for many years but am always looking for something better.
5/27/15       #4: Pre-cat VS Post Cat ...
Tim G
post cat lacquer is just that, same as what you're using except you catalyze it yourself. It is more durable than pre-cat, but not as durable as CV, which is a varnish, making it a bit tougher. Someone with better understanding of the chemistry may post in better detail.
5/28/15       #5: Pre-cat VS Post Cat ...
Jim Clark
I switched to CV a couple yrs ago,
I think it sprays way easier than lacquer.
Takes less, sets up faster, just easier
to work with.
5/29/15       #6: Pre-cat VS Post Cat ...
Joel
Thanks for the responses. I guess it is time for me to step it up with CV. Everybody else has. Now I just have to figure out where to get it. The SW pro store in CT won't sell to me because I don't have a spray booth. They actually visit your shop and verify! Just have to use MLC I guess. I find their pre-cat laq solvent pops a little quicker than SW but they are pretty close otherwise.
