how do you get the pink out of alder
6/17/15
Phil Burruss
I am putting a grey stain over alder wood.It casts a pink tint.We have put a medium stain on it first then the grey stain .still pink cast.How do i get that pink out?
6/17/15       #2: how do you get the pink out of alde ...
Max Neu
i usually dye it with green , or add green to the stain, or sometimes both.
6/17/15       #3: how do you get the pink out of alde ...
Max has it right.
6/19/15       #4: how do you get the pink out of alde ...
Denny J
Yes, anything with a green tint.
6/19/15       #5: how do you get the pink out of alde ...
Charles Member
Purchase a color wheel. Or, just look one up on the web.
Find the offending color (pink). Then, look across the opposite side of the wheel. There you will find the color you need (green) to counteract the first color. (OK, "counteract" is probably not the correct technical term. But green will offset pink.)
