Magnamax or Resistant
6/26/15
Edi Silva  Member
Website: silvawoodworking.com
Hello All
We have been using Magnamax for the last 5 years, but once and while we came across with some water issues around the kitchen sinks , and garbage cabinet. Assuming that the clients are splashing water on the doors and drawer fronts, and not drying. Also some complain about wear and tear, clients saying that the paint we use is not strong enough, it chips when they hit the cabinet with something. Well, no different if they hit their $100k Mercedes with something, it will damage.
Questions is: any of you guys out there that used to use Magnamax have switch to Resistant? did it help with the water issues?( if you had any) . have you notice any difference on the finish durability between the two? All the shops surround our area here are sold on Magnamax, not me. thanks for your help,
Edi
6/26/15       #2: Magnamax or Resistant ...
Mastercabman
CV!
That's all I can say
Every cabinet manufacturer that I install uses CV
6/27/15       #4: Magnamax or Resistant ...
RobertJ
2nd No on Magnamax for kitchens.
CV is the KCMA standard.
Magnamax is for built-ins and/or cabinetry in bedrooms, living rooms, library, office etc.
6/29/15       #5: Magnamax or Resistant ...
Dan/drbwoodworks
We have used magnamax in kitchens with no problem . As long as you use claw lock for primer . On the advice from our local MLC salesman .
7/16/15       #6: Magnamax or Resistant ...
hen bob Member
Skip the Resistant and go right to the "Stealth" , dries faster and harder!!
7/23/15       #7: Magnamax or Resistant ...
Matt
I've sprayed Magnamax, Magnalac, Resistant, and Stealth.
Of the four, Stealth is the best in my experience for production. I rule out Magnamax and Magnalac because they are precat laquers (ie, not as durable as CV) and neither are water white. I can assure you the clear yellows over time, I have products in my house I sprayed with it that look much more yellow now, 9 years later, than they did when I first sprayed them.
That being said, Stealth is my preferred, but even that product I don't like. I found that I had to do a lot more chemical/thinner cocktails to get it to cure properly than I should. It does NOT like hot weather at all.
I eventually started spraying a product from Sherwin Williams that is the most stable white CV I've ever seen (Kemvar plus), look into that if you have a SW branch near you.
