Make Up Air
8/26/15
Nick Cook Member
Website: http://www.cedarrivercabinetry.com
Hello,
We're installing a Reznor make up air unit in a new to us building. Are there guidelines or considerations for the placement of the unit as it relates to our spray booth? We have a separate 2500 sq. ft. area that houses our booth and plenty of wall space to have the air come in. We could also have the air come in on the production side of the shop but this would move air across the production side. Any help or referral to resources would be great. Thanks
8/26/15       #2: Make Up Air ...
Snaglpuss
We have a non heated one that opens when the booths are on but we have it near the booths.
The finishers already complain about dust so I imagine sucking extra dust through the shop into the spray room wouldn't be such a great idea.
8/26/15       #3: Make Up Air ...
chris
how close is it to your gas line. in winter it will be using close to 1 million BTU so you need a good supply
i had to use propane as the building i'm in did not have an adequate supply.
also the further away from the booth the make up unit is means more ductwork creating more drag.
get one with a variable speed fan so you can slow it down for drying.
8/27/15       #4: Make Up Air ...
afinisher
Definitely plan for the makeup air to come into the separate area for your booth. Typically it would be at the far end of the room opposite the booth.
However- I would urge to find professional help in understanding all the considerations so you don't spend a lot of money only to find you make a big mistake in the specs or installation.
When I installed my new open face booth and air makeup, my supplier rep for the booth was experienced and well versed on exactly how the makeup air was to be configured. I would suppose the supplier for the air unit would also provide this support.
In some ways moving air is governed by very simple rules. If you purchase an enclosed booth with air makeup there are fewer variables with the makeup air, but if it is an open face booth at one end of a room then planning for optimum air movement in the room gets more complicated.
If you can't seem to find the support you need, then see if you can locate a body shop owner with a proper booth setup and ask him for a referral to a pro. This is too important and too expensive to depend on trial and error.
