glazing
10/13/15
dar
I am glazing over a super white post cat lacquer and I don't want to have to spray a clear coat over glaze, the glaze is just a highlight glaze in a rope molding on cabinet doors, does anyone know of a glaze that does not need to be locked in and wont bite into white based coat thanks
10/13/15       #2: glazing ...
Shane
you should probably use amazing glaze or similar product in that situation and be deliberate where you apply the glaze..... with a precat you have to wait 24 hours before the glaze or it may bit into and shift the color if you get heavy handed
10/13/15       #3: glazing ...
JeffA
You could use regular house paint. Wipe it on and wipe it off. Whatever is left will have some of the protection of the resin in the paint.
As a fyi, I used that to 'clean' the grout on my tiled floor. Wiped on the paint, took a damp sponge and cleaned the excess paint off that didn't soak into the glaze. Floor looks brand new.
10/14/15       #4: glazing ...
JeffA
"soaked into the glaze." should have said soaked into the grout.
