White topcoat
1/9/16
Stefano
I have hard time to achieve bright white spraying water base lacquer on maple. I usual apply two coat of white primer and two coat of white top coat. The problem I found is that because the primer it isn't bright white, after I apply the two white top coat on top of the primer, the final result it isn't bright white like the paint it self. If I spray 5/6 coats of white top coat instead of two coat it look better but I can't effort to apply 5/6 coats every time. Someone told me that it should be something call ''base coat'' that help to hide the dark of the primer tone. Thank you for help
Stefano
1/10/16       #2: White topcoat ...
Robert Member
How much are you thinning out the top coat? If you are using a white primer correctly there should almost be no reason that two top coats can't achieve your desired color. Often white colors have very little dispersed pigment. Meaning it can't cover very well. Is the primer color ghosting through? Don't thin the top coats if the pigment load is minimal. Also what is the maximum dry mill thickness allowed by the manufacturer. You definitely need to know this. It will tell you how many coats you can apply.
1/10/16       #3: White topcoat ...
Stefano
Thanks Robert, I add not more than 5% water to General Finish to achieve 55 second viscosity in Sata #4,yes I think the primer color ghosting through, since the white top coat itself has the color I want.
1/10/16       #4: White topcoat ...
Robert Chickey Member
Is this a stock color of White? Is there any pigment in the lacquer? I would not thin the product at all. How much difference is there between the primer color and the top coat color? Can you post a picture of the piece you are finishing?
1/12/16       #5: White topcoat ...
Joe
sounds like your white paint may not be quite white enough.....try a touch of Black or Blue pigment.
1/14/16       #6: White topcoat ...
Stefano
Thank you. yes I added a little pigment to correct the color but I thinned a little bit (5% water)
