Augalente Plus
1/19/16
Paul Stover Member
Has anyone had good results with ML Campbell's new Augalente Plus?
My results were less than stellar. The material was really thin and acted like it had no body, it would sag on vertical surfaces, and we couldn't get it to level out properly on horizontal surfaces. It wouldn't sand at all, sandpaper would load up with those little pill balls, even after waiting over night. Our viscosity was 25 seconds @77degrees in a ford cup.
Called ML's tech line and was told that it should outperform the old Augalente in yellowing and hardness. They also said it should sand to a nice powder like the old, and the viscosity should be 32-37 seconds @77 degrees.
I'm wondering if my product went through a freeze thaw cycle before it came to the shop.
1/21/16       #2: Augalente Plus ...
Arthur Grudko
Paul,
What grit and type of sandpaper did you use between coats? Was it No-Fil (stearated)?
1/21/16       #3: Augalente Plus ...
Paul Stover Member
Arthur,
Had our best luck using 220 grit. Still loaded up with the pill balls. Same paper weve been using for 10 years.
3m stikit rolls with the no load open coat paper designed for finishing, we normally use 320 grit. The old augalente sanded very nicely to a powder with little to no loading.
Have you used the new plus?
1/21/16       #4: Augalente Plus ...
Arthur Grudko
Paul,
No, haven't tried it. Just wanted to make sure you were using a no-fil type paper between coats. This new formula must have an additive that slows down the dry time too much.
1/22/16       #5: Augalente Plus ...
Jason Balm Member
We have had our own set of issues (stacking) with agualente plus, but haven't noticed any sanding issues like you are mentioning. We use the stain blocking primer under it so the sanding needed between finish coats is minimal at the most. The primer sands easily.
