Finishing Paper Backed American Walnut
1/30/16
Pete Member
Hello, all:
I am in the process of restoring a pair of large, vintage speakers and I have used paper-backed American walnut using wood glue applied with a roller to both surfaces, dried and then ironed-on, which worked very well. My question is finishing as I would like to fill the grain so the feel is like glass but ultimately, I want a satin sheen; not a high-gloss piano finish. I have new to wood finishing and have searched high and low and I'm now overwhelmed with the different ways to finish. I have a attached a picture of one of the speakers. Any and all advice is genuinely and greatly appreciated! Thanks, Peter.
2/3/16       #3: Finishing Paper Backed American Wal ...
Shane
Peter,
To fill the pores completely is going to take a little blood sweat and tears if you don't have access to the right products. locate some paste wood filler (Sherwin Williams can tint the filler to a certain degree) if your trying to stay natural tint the filler as close as possible to the woods natural color. Search some techniques on how to apply the filler and removing it.... It's going to take a few rounds of the filling process... might as well make sure it's thorough because shooting and sanding over and over till the grain is totally full is not fun... Once you start the finishing process try to use finishes that are high solids like a decent conversion varnish... take note on your total dry mill thickness after all you coats have dried. you don't want your finish cracking after it has dried. it's pretty much going to take spraying and sanding back flat over and over to fill the pores and keep the finish thin....
