creating used barn wood
2/1/16
I have been asked to build a bunch of barn wood furniture and do some feature walls.
I thought I would venture out and find some, I talked to some farmers and found some old grain bins and came up with some used material. The problem I have found is that most of these buildings have very small dimensional lumber so haven't been able to find any bigger pieces.
I was wondering if anyone has come up with some finishes or finishing techniques to create some good older looking barn boards? Thanks for any suggestions.
2/1/16       #2: creating used barn wood ...
nick
Last summer I did 3,000 linear ft. of 1x6 and 1x4 in various lengths. The wood was actual barn wood but the wood wasn't barn wood enough for the designer and architect so the wood shop had the wood sand blasted. The blasting removed most of the mottled grey color and it was my job to bring it back. I made a simple black dye/white pigment wash stain and it came out close to perfect. There is a good chance I was lucky in achieving the mottled look seeing as the wood was old and unevenly blasted but it could work on new blasted wood as well (or not). I have the recipe written down at the shop If you want it let me know and I'll post it. also the wood was used in making accent walls in a college dorm so in an attempt to keep the splinters at a minimum I top coated with 2 thin coats of Target 8000 flat sheen.
2/3/16       #3: creating used barn wood ...
Bob "Boardman" Borders Member
You can buy "barnwood" siding from the link below. The shipping is a cost, but I needed 350 sq ft for a project, and in the end it was a good solution. Much less work then cutting lengths, matching widths, tinting or coloring, and of course sourcing the real stuff.
Dura-Groove
2/8/16       #4: creating used barn wood ...
Mitch Suber  Member
Website: subercustomshutters.com
When we use old heart pine reclaimed from barns or warehouses, we are often faced with having little to none of the thicker dimensions. It does take some time, but we glue up the thinner material as needed.
